*swapcards
Swaps the card image of an entity.
*swapcards entity_type mark_id ?target_card_image?
HyperMesh Tcl Modify Command
- In OptiStruct, it is used to swap groups CONTACT and TIE.
- In Nastran (NX) it is used to swap groups BCTSET and BGSET.
- entity_type
- The type of entity to update. Must be set to groups.
- mark_id
- The ID of the mark containing the groups to update. Valid values are 1 and 2.
- target_cardimage
- The target card image to which the entity need to be swapped. If not specified, a default mapping is done.
To swap contacts with IDs 1 and 2:
*createmark groups 1 1 2
*swapcards groups 1
# Handle error
}Version History
14.0.130
2021.1 - Added Nastran (NX) support.
