*loaddefaultattributevaluesfromxml
Loads the entity's default setting values in the specified XML file.
*loaddefaultattributevaluesfromxml ?xmlfilename?
HyperMesh Tcl Modify Command
Loads the entity's default setting values, mandatory values, show/hide values, and so on, that are defined in the specified XML file. If the file name is not specified, it unloads the previously loaded default settings.
- xmlfilename
- The XML file path containing the entity default settings.
Examples
*loaddefaultattributevaluesfromxml D:/settingsfile/EntityDefaults.xml*loaddefaultattributevaluesfromxmlErrors
# Handle error
}Version History
2021.2
