*linedraglinetoformsurface
Drags a trimmed line along a trimmed line to create a surface, and optionally, prepares it for immediate use within the automesher. It can also identify a region in the shape of a line-dragged surface for the automesher to use under the mesh without surface option.
*linedraglinetoformsurface sectionlinelist sectionnodelist draglinelist dragnodelist refplane using_default_vector
HyperMesh Tcl Modify Command
- sectionlinelist
- The ID of the list of lines to be dragged.
- sectionnodelist
- The list ID of the list of zero or two nodes which lie on the lines in the sectionlinelist which will be used to trim the line during surface creation.
- draglinelist
- The ID of the list of lines to drag along.
- dragnodelist
- The list ID of the list of zero or two nodes which lie on the lines in the draglinelist which will be used to trim the line during surface creation.
- refplane
- The orientation plane used to orient the section lines to the drag lines.
- using_default_vector
- 0 - Use plane normal vector
*surfacemode 4
*createlist lines 1 3 4
*createlist nodes 1
*createlist lines 2 2 1
*createlist nodes 2
*createplane 1 0.0000 1.0000 0.0000 0.0000 0.0000 100.0000
*linedraglinetoformsurface 1 1 2 2 1
The *surfacemode(4) directive tells HyperMesh not to pass the information on to the automesher for element creation.
*createlist() and *createplane() are required for this command.
None.
