*morphmanualinit
Initializes the model to prepare for manual morphing.
*morphmanualinit
HyperMesh Tcl Modify Command
Stores the current node locations for the model so that node movements done through any means (morphing or otherwise) can be recorded and saved as a morph after using the *morphmanualapplyenvelope command.
Manually morphed nodes can later be undone and redone, or saved as a shape.
To manually move nodes and apply them to the mesh as if they were handles using internally generated domains with inferred edges, then reject the changes:
*morphmanualinit
<<any commands which move nodes>>
*createmark nodes 1 21 22 23
*createmark elems 1 "all"
*morphmanualapplyenvelope elems 1 nodes 1 1 1.0 1.0 2 0.0 0
*morphmanualrestore
None.
