*CE_ConnectorAreaMesh
This command meshes area connectors.
*CE_ConnectorAreaMesh ce_mark elementsize elem_type elem_type2 link_opposite_edge size_control skew_control edge_mesh_algorithm min_size max_size chordal_dev max_angle param1 param2
HyperMesh Tcl Modify Command
- ce_mark
- Mark of area connectors.
- elementsize
- Element size for meshing.
- elem_type
- Flag indicating the elements generated for mapped meshing algorithms. Valid values are:
- elem_type_2
- Flag indicating the elements generated for free meshing algorithms. Valid values are:
- link_opposite_edge
- Make opposite edge having the same node density.
- size_control
- Determines if uniform size elements in mapping algorithms should be created.
- skew_control
- Determines if optimal shape elements in mapping algorithms should be created.
- edge_mesh_algorithm
- Determines the algorithm for edge/surface meshing:
- min_size
- Minimum edge size for chordal deviation edge meshing..
- max_size
- Maximum edge size for chordal deviation edge meshing.
- chordal_dev
- Chordal deviation for chordal deviation edge meshing.
- max_angle
- Maximum angle value (in degrees) between edges for chordal deviation edge meshing.
- param1
- For future use.
- param2
- For future use.
Examples
*createmark connectors 1 3
*CE_ConnectorAreaMesh 1 1 1 1 1 0 0 0 0 0 0 0 0 0.0
