*CE_SetSpecificDetailById
Sets a specific detail for a specific connector ID.
*CE_SetSpecificDetailById ce_id detail_type int_val dbl_val
HyperMesh Tcl Modify Command
- ce_id
- A single connector ID.
- detail_type
- The number for the connector detail you are editing:
- int_val
- Pass necessary integers values through this parameter.
- dbl_val
- Pass necessary double values through this parameter.
Examples
*CE_SetSpecificDetailById 8 1 3 0.0
*CE_SetSpecificDetailById 13 101 0 5.0
