*attributeupdatestringarray
Updates an attribute of type string array.
*attributeupdatestringarray entity type id identifier solver status behavior data length
HyperMesh Tcl Modify Command
entity type
The type of entity that owns the attribute.
id
The ID of the entity.
identifier
The identifier of the attribute.
solver
The solver number of the attribute.
status
The status of the attribute.
behavior
The behavior of the attribute.
data
The string array.
length
The string array length.
Examples
Update an attribute of type string array to [layer1, layer2] on the material with ID 7.
*createstringarray 2 "layer1" "layer2"
*attributeupdatestringarray materials 7 615 2 2 0 1 2
