*morphupdatedomains
Updates global domains.
*morphupdatedomains mode
HyperMesh Tcl Modify Command
- mode
- Always 0 global domains.
*morphupdatedomains 0
This command updates any global domains which are not assigned any nodes (those created with versions of HyperMesh prior to 8.0) to be assigned all the nodes in the model.
None.
