*elementqualityundoaction
Reverses the effects of the last specified command within the interactive element cleanup tool.
HyperMesh Tcl Modify Command
Within the interactive element cleanup tool, reverses the effects of the last specified command.
This command only functions between a *elementqualitysetup() command and a *elementqualityshutdown() command.
