*createentity
Create a new entity with specified data.
*createentity entity_type ?modelname=<name_of_model>? ?name1=value1? ?name2=value2? ... ?name3=valueN?
HyperMesh Tcl Modify Command
Create a new entity with specified data. Data names only are allowed to be set. If the data name “name” is specified when creating an entity enabled for the name pool, the command uses the provided name to define the solver name.
- Attributes are not supported.
- STATUS is not supported.
- entity_type
- Entity type to create.
- <name>=<value>
- The name=value data name and/or attribute pairs that define the relevant data for the entity. For attributes, this can be either the attribute name or ID.
- modelname=<name_of_model>
- This is the optional model name to update when there are multiple models in the database. If not specified, the current model is used.
Examples
*createentity sets*createentity sets type=1 ids={1 2 3 4}*createentity sets name=set1 cardimage=GRNOD*createentity nodes x=100 y=200 z=0Errors
# Handle error
}Version History
13.0
2020.1 - Added new option modelname.
