*solverconvert
Converts a model from one solver to another.
*solverconvert source_solver destination_solver source_type destination_type batch ?config_file_path?
HyperMesh Tcl Modify Command
This command converts a model from one solver to another.
| Solver Name | Solver ID | Solver Type |
| Nastran | 1 | |
| OptiStruct | 1 | |
| Abaqus | 2 | Standard2D, Standard3D, Explicit |
| ANSYS | 8 | |
| LS-DYNA | 9 | Keyword971_R12.0, Keyword971_R11.2, Keyword971_R10.1, Keyword971_R9.3,Keyword971_R8.0, Keyword971_R7.1, Keyword971_R6.1, Keyword971, Keyword970 |
| PAM-CRASH | 18 | Pamcrash2G2020, Pamcrash2G2019, Pamcrash2G2018, Pamcrash2G2017, Pamcrash2G2016, Pamcrash2G2015, Pamcrash2G2014, Pamcrash2G2013, Pamcrash2G2012, Pamcrash2G2011, Pamcrash2G2010, Pamcrash2G2008, Pamcrash2G2007, Pamcrash2G2006, Pamcrash2G2005, Pamcrash2G2004 |
| Radioss | 20 | Radioss2022, Radioss2021, Radioss2020, Radioss2019, Radioss2018, Radioss2017, Block140, Block130, Block120, Block110, Block100, Block90, Block51, Block44 |
| Permas | 21 | Permas |
| ADVC | 30 | advc |
| Source Solver Name | Destination Solver Name |
| Abaqus | Nastran |
| Abaqus | OptiStruct |
| ANSYS | Nastran |
| ANSYS | OptiStruct |
| LS-DYNA | Nastran |
| LS-DYNA | OptiStruct |
| Radioss | PAM-CRASH |
| PAM-CRASH | Radioss |
| Nastran | Abaqus |
| OptiStruct | Abaqus |
| Nastran | ANSYS |
| OptiStruct | ANSYS |
| Nastran | LS-DYNA |
| Nastran | Radioss |
| OptiStruct | Radioss |
| ANSYS | Abaqus |
| Nastran | OptiStruct |
| Abaqus | Radioss |
| ADVC | OptiStruct |
| LS-DYNA | PAM-CRASH |
| LS-DYNA | Radioss |
| Nastran | PAM-CRASH |
| PAM-CRASH | LS-DYNA |
| PAM-CRASH | Nastran |
| Permas | OptiStruct |
| Radioss | OptiStruct |
- source_solver
- The source solver name or ID.
- destination_solver
- The destination solver name or ID.
- source_type
- The source solver template type.
- destination_type
- The destination solver template type.
- batch
- Flag that indicates if the conversion should be run in batch mode.
- 0 - No batch mode
- 1 - Batch mode for Solver Conversion
- 2 - Batch mode for Unified Conversion
- ?config_file_path?
- The full path for the configuration file containing the entity mapping details, to be used for the conversion. This is useful when the user has restrictions on modifying the file in the installation. When the configuration file path is not specified or the path is not valid, the conversion will use the default configuration file from the installation.
Examples
*solverconvert Abaqus OptiStruct Standard3D "" 1*solverconvert 2 1 Standard3D "" 1*solverconvert RadiossBlock Pamcrash Block90 Pamcrash2G2007 0*solverconvert 20 18 Block90 Pamcrash2G2007 0*solverconvert "Abaqus" "RadiossBlock" "Standard3D" "Radioss2021" "2" ""*solverconvert 2 20 "Standard3D" "Radioss2021" "2" ""Errors
# Handle error
}Version History
11.0
2017.1 - Added a new optional argument config_file_path. Updated list of supported solver versions.
