*morphupdatemvedgenodes
Updates the mid-nodes of the specified morph volume edge.
*morphupdatemvedgenodes nodes hand
HyperMesh Tcl Modify Command
- nodes
- Mark number of node list.
- hand
- 0 = do not create handles for morph volumes
*morphupdatemvedgenodes 1 1
This command changes the nodes for a given morph volume edge to be those of the node list. The first and last nodes on the node list should be the original end nodes of the morph volume edge.
None.
