*marknodenudge
Moves nodes along a surface. The nodes must first be associated to a surface.
*marknodenudge mark distance vector
HyperMesh Tcl Modify Command
mark
The mark containing the nodes to be moved.
distance
The distance to move the nodes (in the direction of the vector).
vector
The direction to move the node (in 3D space). This vector is mapped to the surface before the nodes are moved.
To move the node with ID 110 a distance of 10 in the x direction (along the surface it is associated to):
*createmark nodes 2 110
*createvector 1 1.0 0.0 0.0
*marknodenudge 2 10.0 1
*createmark() and *createvector() are required for this command.
None.
