*interfaceadd
Creates interface elements.
*interfaceadd name main type mark reverse
HyperMesh Tcl Modify Command
name
The name of the group into which the interface elements should be placed.
main
Use 1 for main; 0 for secondary.
type
The entity type of the secondary entities (none, elements, nodes).
mark
The ID of the mark containing the nodes or elements which should have main or secondary elements placed on them.
reverse
A logical which determines if the secondary elements should be reversed when created.
None.
