*settrimcuttingplanes
Turns the cutting plane trim option on/off.
*settrimcuttingplanes state
HyperMesh Tcl Modify Command
- state
- Specifies the trim plane option for all cutting planes. Valid values are:
To turn off the trim cutting plane option:
*settrimcuttingplanes 0
None.
