*segmentsetcreatewithmixedfaces
Creates a segment set using a mixture of solid elements and shell elements.
*segmentsetcreatewithmixedfaces name color elem_mark_id node_mark_id break_angle reverse_normals
HyperMesh Tcl Modify Command
name
The name of the segment set to create.
color
The color of the segment set. Valid values are 1-64.
elem_mark_id
The ID of the mark containing the elements to use. Valid values are 1 and 2.
node_mark_id
The ID of the mark containing the nodes that define an edge or a face of an element. Valid values are 1 and 2.
break_angle
The break angle for finding adjacent elements.
reverse_normals
Create segment set:
0 - Along element normal
1 - Opposite element normal
Examples
To create a segment set named "test" with elements 1-100 with faces defined by nodes 1-5 and a break_angle of 30.0:
*createmark elems 1 1-100
*createmark nodes 1 1-5
*segmentsetcreatewithmixedfaces "test" 5 1 1 30.0 0
   # Handle error
Version History
2020
