*cleanup_unoffsetable_nodes
Smooths the area around any unoffsetable nodes to attempt to make them offsetable.
*cleanup_unoffsetable_nodes entity_type mark_id angle_threshold layers iters
HyperMesh Tcl Modify Command
Smooths the area around any unoffsetable nodes to attempt to make them offsetable. Useful for CFD BL meshing.
Consider a node and all its surrounding elements. The visibility angle of an element is the signed angle between the node normal and the element normal after subtracting 90 degrees. The visibility angle of the node is the minimum of the element visibility angle for all surrounding elements. The best visibility angle of the node is the maximum of the node visibility angle for all choices on the node normal. A node having zero or negative best visibility angle is considered absolutely unoffsetable. A node having its best visibility angle less than angle_threshold is considered unoffsetable.
- entity_type
- The type of entity used as input. Valid values are comps and elems.
- mark_id
- The ID of the mark containing the input entities. Valid values are 1 and 2.
- angle_threshold
- A value ≥ 0.0 and < 45.0 that defines the threshold visibility angle in degrees for determining a node is unoffsetable.
- layers
- Defines the number of adjacent layers to consider for the smoothing. Must be ≥ 1. A value between 1 and 3 is generally recommended.
- iters
- The number of smoothing iterations to perform. Must be ≥ 1. A value between 1 and 5 is generally recommended.
Examples
*createmark elements 1 10-13
*cleanup_unoffsetable_nodes elems 1 2.5 2 3
# Handle error
Version History
14.0
