*updateinclude
Updates include file basic information.
*updateinclude id shortname_flag shortname fullname_flag fullname parentid_flag parentid
HyperMesh Tcl Modify Command
id
The ID of the include file to update. If 0, the shortname is used instead.
shortname_flag
0 - Do not update the file short name.
1 - Update the file short name.
shortname
The new short name if shortname_flag is 1, or the short name used to select the file if ID is 0.
fullname_flag
0 - Do not update the file full name .
1 - Update the file full name.
fullname
The new full name if fullname_flag is 1.
parentid_flag
0 - Do not update the parent ID.
1 - Update the parent ID.
parent_id
The new parent ID if parentid_flag is 1.
To change the include file with ID 1, stored as C:/common_files/mats/mat1.dyn from mat1.dyn to mat2.dyn and change its parent from the main file to a file with ID 3:
*updateinclude 1 1 mat2.dyn 1 C:/common_files/mats/mat2.dyn 1 3
   # Handle error
