*rigidlinkinodecalandcreate
Creates a rigidlink elem by calculating the independent node based on selection of dependent nodes. Location of independent nodes will be at the geometric center of dependent nodes.
*rigidlinkinodecalandcreate node_mark1 set_id attach_set_option dof
HyperMesh Tcl Modify Command
node_mark1
Mark for multiple dependent nodes.
set_id
Set that contains dependent nodes. Set type should be of nodes.
attach_set_option
Options for attaching set to rigidlink:
0- set will not be created when multiple dependent nodes are selected.
1- set will be created when multiple dependent nodes are selected and then assigned to rigidlink.
dof
Degrees of freedom. This is a six digit number.
For creating a rigidlink elem by selecting only dependent nodes without the attach set option:
*rigidlinkinodecalandcreate 2 0 0 123456
For creating a rigidlink elem by selecting only dependent nodes with the attach set option:
*rigidlinkinodecalandcreate(2,0,1,123456)
For creating a rigidlink elem by selecting only dependent node set with the attach set option:
*rigidlinkinodecalandcreate(0,2,1,123456)
*createmark() for nodes is required if a dependent node set is not selected.
None.
