*morphmapnormaloffset
Offset elements on mark in normal direction.
*morphmapnormaloffset typeelem markelem typefix markfix sym con blend offset umark
HyperMesh Tcl Modify Command
- typeelem
- Elems
- markelem
- Mark number of elements to map
- typefix
- Nodes
- markfix
- Mark number of fixed nodes
- sym
- 0 - Do not use symmetry (only option)
- con
- 0 - Do not use constraints
- blend
- 0 - Do no blend unselected nodes
- offset
- Distance to offset elements
- umark
- 0 - Use all elements to calculate normals
*morphmapnormaloffset ELEMS 1 NODES 1 0 1 0 10.0 1
If blend is on, no fixed nodes have been selected, and no mapped nodes are a part of any domain, this command will automatically assign all non-mapped nodes as fixed nodes.
None.
