*setsystem
Sets the element (material) orientation by setting the angle. This angle is measured from the I-J (1-2) edge of the element around the normal of the element. Re-orients and visualizes the element (material) coordinate systems for selected elements.
*setsystem entities markmask setangle onlyorient normal_size color
HyperMesh Tcl Modify Command
- entities
- Determines the selected entity, which can only be elements.
- markmask
- Determines the selected elements.
- setangle
- Determines the constant angle offset.
- onlyorient
- 1 - The new x-element directions are shown as vectors starting from the element center.
- normal_size
- If onlyorient = 1, this determines the size of the vectors to be displayed.
- color
- Determines the color of the vector or line. The color ID number ranges from 1 to 64.
*createmark elements 2 376 377 389 418
*setsystem elements 2 45 1 3 7
*vectorsoff The *createmark() and *vectorsoff() commands are required.
None.
