*usercheck
Runs a template that can be used to check element quality.
*usercheck template_file output_file all
HyperMesh Tcl Modify Command
- template_file
- The name of the template file.
- output_file
- The name of the output file.
- all
- Determines the entities the template scans.
The template file can use the *markfailed() template command to mark elements that do not pass any user-specified test. *markfailed() highlights the element on the screen and also puts the element on the user mark.
None.
