*morphconstraintcreateelems
Creates a mesh type morphconstraint for the selected nodes with the option of having those nodes either move along the specified mesh or be bounded by it.
*morphconstraintcreateelems ntype nmark etype emark type name p_vec dist ivec color
HyperMesh Tcl Modify Command
This command creates a mesh type morphconstraint for the selected nodes with the option of having those nodes either move along the specified mesh or be bounded by it.
The extended edges option is available for bounded type morphconstraint (types 1, 3, and 5) by adding 8 to the type (9, 11, and 13). This option will extend the edges of the mesh by roughly two element lengths so that the nodes which project close to the edges of the mesh will project on to the extended edges.
The depenetration option is available for bounded type morphconstraint (types 1, 3, and 5) by adding 16 to the type (17, 19, and 21). This option will treat the center of any element attached to the constrained nodes as a constrained node and push the element away from the mesh if it is within the specified distance.
To enable both extended edges and depenetration for a morphconstraint, add 24 to the type (thus 1, 3, and 5 become 25, 27, and 29).
- ntype
- Must be set to nodes.
- nmark
- The mark ID for the constrained nodes. Valid values are 1 and 2.
- etype
- Must be set to elems.
- emark
- The mark ID for elements to which the nodes are constrained. Valid values are 1 and 2.
- type
- 0 - moves along mesh
- name
- The name of the morphconstraint.
- p_vec
- The ID of the projection vector created using *createvector. Must be set to 1.
- dist
- Distance between node and mesh (types 1 and 3).
- ivec
- 0 - Mesh normal is used for projection. The nodes will be moved normally to the mesh when constraining them or measuring the distance the nodes are away from the mesh
- color
- The color of the constraint. Valid values are 1-64.
To create a morphconstraint for nodes to move along a mesh and projected normally to the mesh:
*createmark nodes 1 1 2 3 4 5
*createmark elems 1 11 12 13 14 15
*createvector 1 1.0 0.0 0.0
*morphconstraintcreateelems nodes 1 elems 1 0 "mcon" 1 0.0 0 13
To create a morphconstraint for nodes to be bounded by a mesh at a distance of 5.0 and projected along a vector to the mesh with both depenetration and extended edges:
*morphconstraintcreateelems nodes 1 elems 1 27 "mcon" 1 5.0 1 13
# Handle error
