*createnodesbetweennodes
Creates a user-specified number of nodes between two nodes.
*createnodesbetweennodes node1 node2 number
HyperMesh Tcl Modify Command
node1
The first of 2 nodes between which new nodes should be created.
node2
The second of 2 nodes between which new nodes should be created.
number
The number of nodes which should be created between node1 and node2.
Examples
To create 5 nodes between nodes 100 and 101:
*createnodesbetweennodes 100 101 5
