*viewset
Sets the graphics view.
*viewset a00 a01 a02 a03 a10 a11 a12 a13 a20 a21 a22 a23 a30 a31 a32 a33 minx miny maxx maxy
HyperMesh Tcl Modify Command
Sets the model orientation and visible area. The current values can be queried using hm_winfo viewmatrix.
a00-a33
The 4x4 matrix to use to define the view. The current values can be queried using hm_getcurrentview.
minx
The viewport x-axis minimum value.
miny
The viewport y-axis minimum value.
maxx
The viewport x-axis maximum value.
maxy
The viewport y-axis maximum value.
To orient the model so the z-axis is pointing out of the screen, with the max visible area set to (-0.5,-0.5) to (0.5,0.5):
*viewset 1 0 0 0 0 1 0 0 0 0 1 0 0 0 0 1 -0.5 -0.5 0.5 0.5
   # Handle error
