*realizeengineeringentity
Realize an engineering entity.
*realizeengineeringentity entity_type entity_id reserved
HyperMesh Tcl Modify Command
- entity_type
- The type of engineering entity to realize.
- entity_id
- The ID of the engineering entity to unrealize.
- reserved
- Reserved for future use. Must be set to 0.
Realize the mass entity with ID 10:
*realizeengineeringentity masses 10 0
# Handle error
}Version History
2017.2
