*encryptentity
Encrypts an entity.
*encryptentity entity_type id key
HyperMesh Tcl Modify Command
Encrypts an entity. Currently only supported for Radioss.
- entity_type
- The type of entity to encrypt. Valid values are curves, mats and props.
- id
- The ID of the entity to encrypt.
- key
- For Radioss, this is the value to use for /KEY. Valid values are 01-99.
*encryptentity mats 100 55Errors
# Handle error
}Version History
14.0.120
