*penetrationrecheck
Modifies the element thickness to correct penetration problems.
*penetrationrecheck mark reduction scale display_mode normal_scale label segment magnitude_mode
HyperMesh Tcl Modify Command
- mark
- The mark of the entity to be modified.
- reduction
- The average thickness reduction.
- scale
- The thickness scale factor.
- display_mode
- The type of entity to be displayed.
- 0 - Nodes
- 1 - Normals
- 2 - Contour
- normal_scale
- The magnitude percentage or the uniform size.
- label
- The label vector option.
- segment
- The segment orientation option.
- magnitude_mode
- Determines if a magnitude percentage or a uniform size is to be used.
- 1 - Magnitude percentage
- 0 - Uniform size
To modify the element thickness:
*createmark groups 1 "E2E"
*penetrationrecheck 1 0 1 0 1 1 1 1
*createmark() and *templatefileset() are required.
None.
