*absorbmember
Absorbs existing 1D elements or lines to skeleton entities.
*absorbmember entity_type break_angle=<value> create_legs=<value> ?mark=<mark_id>? ?prefix=<value>?
HyperMesh Tcl Modify Command
Absorbs selected entities (1D elements or lines) to create members and memberjoints (from connecting nodes or points). If 1D elements are absorbed and they have a beamsection assigned to them, a membersection containing the beamsection is created and assigned to the member. No cleaning operation is performed at the end of the absorption.
entity_type
The entity type to absorb. Valid values are elements and lines.
along_line=<value>
The flag to create control locations of member on the line selected.
Valid values are 0 and 1.
auto_detect_thin_solids=<value>
The flag to detect thin solids for the realized beam section of the member section. This flag works only if the intersectingentitytype dataname is set to solids (55).
autoweld=<value>
The flag to perform auto weld on the realized beam section of the member section.
break_angle=<value>
The break angle limit (in degrees) to define if two continuous members may be merged into a single member.
create_legs=<value>
The flag defining if legs should be created on memberjoints. Valid values are 0 and 1.
If 1, the leg size is set to 10% of the member size.
create_member_sections=<value>
The flag to create member sections on memberjoints and members created during the process.
create_sketch=<value>
The flag to create sketch entity on beam section when member section is realized. Only supported for section type "real".
elemconfig=<value>
The element config of the 1D elements of member joint mesh. For example, bar2, rod.
elemdensity=<value>
The element density to be used for meshing the member joint leg.
elemsize=<value>
The size of the 1D elements to be created during meshing if elemdensity is not specified.
elemtype=<value>
The element type of the 1D element of member joint mesh. For example, CBAR, CBEAM, CROD.
mark=<mark_id>
The ID of the mark containing the entities to absorb. Valid values are 1 and 2.
If mark isn’t provided, absorption is performed to all entities.
planelength=<value>
The length of the member section plane.
planewidth=<value>
The width of the member section plane.
prefix=<value>
The prefix for the member name.
realize=<value>
The flag to realize member joints, members and member sections created during the process.
sectiontype=<value>
The section type string for beam section. Valid values are:
"real" – creates shell or solid beam sections.
"boundingbox" – creates a standard box type beam section equivalent to the bounding box of the real section.
useelemdensity=<value>
The flag determines if element density is to be used for meshing the member joint. Valid values:
0 – False
1 – True
vertex_angle=<value>
Section contour is smoothened if vertex angle between two lines is below this limit. Valid values are between 0 to 90.0.
Examples
To absorb displayed lines:
*createmark lines 1 displayed
*absorbmember lines mark=1 create_legs=1 break_angle=10
To absorb elements ID 1-100 with a name prefix "top_":
*createmark elements 1 1-100
*absorbmember elements mark=1 create_legs=0 break_angle=10 prefix="top_"
Absorbing a mark of lines to create sections:
*createmark lines 1 3
*absorbmember lines mark=1 create_legs=0 create_member_sections=1 numcontrollocs=3 realize=1 autoweld=1 auto_detect_thin_solids=1 create_sketch=0 along_line=1 intersectingentitytype=2 planelength=300 planewidth=300 vertexangle=60 break_angle=1 elemconfig=bar2 elemtype=CBEAM elemsize=40.000000 sectiontype=real
   # Handle error
Version History
2022
2023 - Added new options along_line, auto_detect_thin_solids, autoweld, create_member_sections, create_sketch, elemconfig, elemdensity , elemsize, elemtype, planelength, planewidth, realize, sectiontype, useelemdensity, and vertex_angle.
