*summary
Prints or displays a summary from a specified template.
*summary template_file output_file print all
HyperMesh Tcl Modify Command
template_file
The name of the template file from which the format of the summary file will be obtained.
output_file
The name of the file that the information will be printed out to (information will still be displayed on screen).
print
If set to 0, information will be printed only to screen.
If set to 1, information will also be sent to printer.
all
0 - Only displayed portions of model will be taken into account when creating the summary template.
1 - Everything will be taken into account regardless of whether it is displayed or not.
To obtain a component by component summary for everything in a Nastran model without printing it:
*summary "nastran/components" "output.txt" 0 1
None.
