*CE_ExportOneFile
Export connectors which belong to specified original file in their original or specified format.
*CE_ExportOneFile mark_id ce_style filename option reserved1 reserved2 reserved3
HyperMesh Tcl Modify Command
This command exports selected connectors which belong to a specified original file to the file in original format or specified format. The exported connectors file in XML format can be viewed either in an internet browser or in XML notepad. The ASCII or VIP format file can be viewed in any text viewer.
- mark_id
- The ID of the mark containing the connectors to export. Valid values are 1 and 2.
- ce_style
- Filter the specific type of connector to exported. Valid values are:
- all
- spot
- bolt
- apply_mass
- seam
- area
- filename
- The full path and filename of the original file.
- option
- Specifies the output format:
- 0 - Original format
- 1 - ASCII
- 3 - XML
- 4 - VIP
- 5 - XML 2.0
- 6 - XML 2.0 (version A)
- 7 - XML 2.0 (version B)
- reserved1
- Reserved for future use. Must be set to "".
- reserved2
- Reserved for future use. Must be set to 0.
- reserved3
Examples
*createmark connectors 1 "displayed"
*CE_ExportOneFile 1 "all" "C:/ce_info.xml" 3 "" 0 0
# Handle error
Version History
12.0.110
