*surfacesplitwithline
Splits a surface with a line by sweeping the line along a vector.
*surfacesplitwithline surface line vector entire_surf_flag distance
HyperMesh Tcl Modify Command
- surface
- The ID of surface to be split.
- line
- The ID of the line used to split the surface.
- vector
- The vector used to sweep the line.
- entire_surf_flag
- 1 - The line is swept throughout the entire surface.
- distance
- The distance to sweep line, if entire_surf_flag is set to 0.
To split surface 1 by sweeping line 2 along the x-axis for a distance of 100:
*createvector 3 1.0 0.0 0.0
*surfacesplitwithline 1 2 3 0 100.0
None.
