*morphdeletemvedgenodes
Deletes the selected mid-edge nodes from the edges of morph volume.
*morphdeletemvedgenodes entity_type mark_id
HyperMesh Tcl Modify Command
- entity_type
- Valid values are nodes or handles.
- mark_id
- The mark ID containing either nodes or handles. Valid values are 1 and 2.
Examples
To delete all mid-edge nodes in the model:
*createmark nodes 1 "all"
*morphdeletemvedgenodes nodes 1
To delete a handle and the underlying node from an edge:
*createmark handles 1 13
*morphdeletemvedgenodes handles 1
# Handle error
}Version History
10.0
