*xyplotchangemode
Changes the mode of an extended plot.
*xyplotchangemode plotname mode
HyperMesh Tcl Modify Command
plotname
Name of the extended (dual) plot to change.
mode
New mode value (2 or 5).
*xyplotchangemode "results" 5
Extended (or dual) plots can display data in two modes. In complex mode, (mode=2), the Y-axis of the bottom plot is the real component, while the Y-axis of the top plot is the imaginary component. In phase/magnitude mode (mode=5), the Y-axis of the bottom plot is magnitude (in logarithmic form), while the Y-axis of the top plot is phase. Other mode indices (besides 2 and 5) are reserved for future use.
None.
