*copysegments
Copies segments from original set-segment to another set-segment.
*copysegments set_ids=<value> elem_ids=<value> face_indices=<value> to_segment=<value>
HyperMesh Tcl Modify Command
Copies segments from one or many set-segments to another set-segment. A segment is defined using its corresponding set ID, element ID, and face index.
- set_ids=<value>
- The ordered list of set IDs from which the segments need to be copied.
- elem_ids=<value>
- The ordered list of element IDs corresponding to the segments.
- face_indices=<value>
- The ordered list of face indices corresponding to the segments.
- to_segment=<value>
- The name of the destination set.
Examples
*copysegments "set_ids={5 5}" "elem_ids={78 78}" "face_indices={4 3}" to_segment="set2"Errors
# Handle error
}Version History
2022.1
