*fatiguewrite
Creates a fatigue analysis input file in the format specified.
*fatiguewrite entities markmask filename datagroup filetype analysistype simulationtype sim1 sim2 sim3
HyperMesh Tcl Modify Command
- entities
- The entity types on the mark.
- Elements
- Nodes
- markmask
- The mark ID containing the entities.
- filename
- The specified file name into which the fatigue analysis results are written.
- datagroup
- The data group type chosen (depending upon the solver).
- filetype
- The file type.
- BINARY
- ASCII
- analysistype
- The analysis type.
- Linear
- Transient
- simulationtype
- The simulation types.
- 0
- 1
- 2
- sim1
- If simulationtype = 0, writes all simulations for the specified entities.
- sim2
- If simulationtype = 1, writes only the simulation values for a specific simulation.
- sim3
- If simulationtype = 2, writes only the simulations in the specified range, given start and end simulation values.
*fatiguewrite elements 2 "c:\temp\fatg_file_name" "Stress TOP SURFACE" ascii linear 0 all NULL NULL
Load the HyperMesh model or solver input data and results files prior to using this command.
