*detach_fromelements
Detaches elements from selected elements or nodes.
*detach_fromelements elements from_type from_mark offset
HyperMesh Tcl Modify Command
elements
The elements to be detached.
from_type
Entity type (elems or nodes) from which you want to detach the elements.
from_mark
Selected elements (nodes) from which you want to detach the elements.
offset
Offset value of the newly detached nodes.
To detach element number 16 from two elements with numbers 228 and 243, and an offset of 1:
*createmark elements 1 16
*createmark elements 2 228 243
*detach_fromelements 1 elements 2 1
