*morphmaptshpedge
Adds and edge domain perturbation to the current temporary shape.
*morphmaptshpedge dtype dmark etype emark stype smark lline plane line points niproj iproj clear sym con type
HyperMesh Tcl Modify Command
- dtype
- Domains
- dmark
- Domain mark number
- etype
- Elems
- emark
- Element mark number
- stype
- Surfs
- smark
- Surface mark number
- lline
- Not currently used
- plane
- Mark number of plane
- line
- ID of line
- points
- Mark number of points for a line
- niproj
- Direction of projection:
- clear
- Determine if/how to delete perturbations:
- sym
- 0 - Do not use symmetry (only option)
- con
- 1 - Use constraints (only option)
- type
- The type of target to be mapped to.
*morphmaptshpedge DOMAINS 1 ELEMS 1 SURFS 1 NULL 1 32 1 0 1 0 0 1 1
This command is part of the map to geometry function which consists of multiple commands. This command is called any number of times, first with clear set to 1, then subsequently set to 0, followed either by one of the many *morphmapto…() commands. If clear is set to 2 then the last *morphmaptshpedge() command is rejected.
Type denotes the type of target to be mapped to. Either the plane, line, points, surface mark, or element mark must be filled with a valid entry corresponding to the type selected.
# Handle error
