*attributeupdateintarraymark
Updates an attribute of type int array on a set of entities.
*attributeupdateintarraymark entity_type mark identifier solver status behavior data length
HyperMesh Tcl Modify Command
entity_type
The entity type that owns the attribute.
mark
The number of the mark.
identifier
The identifier of the attribute.
solver
The solver number of the attribute.
status
The status of the attribute.
behavior
The behavior of the attribute.
data
The int array.
length
The int array length.
Examples
Update an attribute of type int array to [1, 2, 3, and 4] on the materials with ID's 7 and 8.
*createmark materials 1 7 8
*createintarray 4 1 2 3 4
*attributeupdateintarraymark materials 1 615 2 2 0 1 4
