*plotnodelist
Plots a curve based on the values of a contour along a list of nodes.
*plotnodelist listid
HyperMesh Tcl Modify Command
listid
The ID of the active node list.
*contourplot "" 0 0 0 0 0 1 0 0 "total disp" 1 0 0
*xyplotsetcurrent "untitled1"
*createlist nodes 1 1601 1600 1599 1598
*plotnodelist 1
In order to work, there must be an existing contour and a list of nodes (not nodes on a mark).
None.
