*nodeplaceatxyz
Moves a node to a location on a surface and associates the node to the surface.
*nodeplaceatxyz node surface location
HyperMesh Tcl Modify Command
- node
- The ID of the node.
- surface
- The ID of the surface to which the node should be associated.
- location
- The location of the point on the surface where the node is to be moved.
To move node 115 to surface 1 at location (75,30,86):
*nodeplaceatxyz 115 1 75 30 86
None.
