*curvemodifypointcords
Modifies the x or y coordinate of an existing point on a curve.
*curvemodifypointcords curve_id point_number xstring xvalue ystring yvalue
HyperMesh Tcl Modify Command
- curve_id
- The ID of the queried curve.
- point_number
- The point number on the curve to be modified. Point numbering starts with 1.
- xstring
- The string identifiers to modify the x coordinate of the point. Valid value is -x.
- xvalue
- The value to be modified of the x coordinate of the point.
- ystring
- The string identifiers to modify the y coordinate of the point. Valid value is -y.
- yvalue
- The value to be modified of the y coordinate of the point.
Examples
*curvemodifypointcords $curve_id 2 -x 5.0 *curvemodifypointcords $curve_id 2 -y 100.0*curvemodifypointcords $curve_id 2 -x 5.0 -y 100.0Either -x xvalue or -y yvalue, or both can be specified. If only x coordinate needs to be modified, specify -x xvalue.
If only y coordinate needs to be modified, specify -y yvalue.
If both x and y coordinates need to be modified, specify -x xvalue -y yvalue.
