*attributeupdateintarray2delementmark
Updates one element of an attribute of type integer array.
*attributeupdateintarray2delementmark entity_type mark identifier solver status behavior row col value
HyperMesh Tcl Modify Command
entity_type
The type of entity that owns the attribute.
mark
The number of the mark where the list of IDs resides.
identifier
The identifier of the attribute.
solver
The solver number of the attribute.
status
The status of the attribute.
behavior
The behavior of the attribute.
row
The row number the value to be changed resides in (first row is zero).
col
The column number the value to be changed resides in (first column is zero).
value
The new value of the 2D array element.
Examples
Assuming you want to update an element in a 2D array attribute to 5 (specifically located at row 3, column 2). The attributes are found on materials with IDs of 7 and 8, you would do the following:
*createmark materials 1 7 8
*attributeupdateintarray2delementmark materials 1 1234 1 2 0 2 1 5
