*writequalitysummary
This command is executed from the 2D page’s Quality Index tool. It has little to no valid usage in custom macro scripts, because it does not perform any calculations.
HyperMesh Tcl Modify Command
Collects a summary of the mesh quality, including details such as the number of quads which fail the Jacobian test or trias with angles exceeding the acceptable number, and writes the results to a formatted text file.
None.
