*surfacespherefromfournodes
Creates a sphere which passes through the four specified nodes, and optionally, prepares it for immediate use within the automesher. It can also identify a region in the shape of such a sphere for the automesher to use under the mesh without surface option.
*surfacespherefromfournodes list
HyperMesh Tcl Modify Command
- list
- The list of the four nodes through which the surface will pass.
To create a sphere which passes through nodes 1, 2, 3, and 4, but not create any elements on the sphere:
*surfacemode 4
*createlist nodes 1 1 2 3 4
*surfacespherefromfournodes 1
*createlist() is required for this command. The *surfacemode(4) directive tells HyperMesh not to pass the information on to the automesher for element creation.
None.
