*morphhandlepertnormal
Perturbs handles on mark normal to elements.
*morphhandlepertnormal handletype markhandle elemtype markelem dist sym con umark
HyperMesh Tcl Modify Command
- handletype
- Handles
- markhandle
- Handle mark number
- elemtype
- Elems
- markelem
- Element mark number
- dist
- Distance of perturbation
- sym
- Flag to use symmetry:
- con
- Flag to use constraints:
- umark
- Flag to only use in the mark:
*morphhandlepertnormal HANDLES 1 ELEMS 1 3.0 1 1 1
All handles on the mark will be given a perturbation equal to dist in the normal direction as determined by either the selected elements or by all elements. If symmetry is used,all handles linked to marked handles by symmetry will also be perturbed. If constraints are used, they will be applied to the perturbations.
None.
