*morphsmooth
Applies smoothing to selected domains.
*morphsmooth dtype dmark method iter
HyperMesh Tcl Modify Command
- dtype
- Domains
- dmark
- Domain mark number.
- method
- The smoothing method to use:
- 1 - Autodecide
- 2 - Size corrected
- 3 - Shape corrected
- 4 - Angle corrected
- 5 - QI optimized
- iter
- Number of iterations of smoothing (methods 1-4 only).
*morphsmooth DOMAINS 1 3 10
This command applies the specified smoothing method to the selected domains as a morph. Thus, it can be undone or redone.
None.
