*modelcheck_applyautocorrectiononmark
Runs auto correction on specific entities for a given check, if checks are run.
*modelcheck_applyautocorrectiononmark check_display_name mark_id ?correction_display_name?
HyperMesh Tcl Modify Command
check_display_name
The GUI display name of the check. This is case sensitive.
mark_id
The ID of the mark of entities for which model checker is to be run. Valid values are 1 and 2.
The GUI name of the correction. This is case sensitive.
If not provided, the then default auto correction associated with the check is applied.
Examples
To run the "Delete unused materials" auto correction for all "Unused materials":
*createmark mats 1 all
*modelcheck_applyautocorrectiononmark "Unused materials" 1 "Delete unused materials"
   # Handle error
Version History
2019
