*saveviewmask
Saves the current view orientation and visible entities.
*saveviewmask view_name visible
HyperMesh Tcl Modify Command
Saves the currently view orientation and visible entities. Views are stored in the database.
- view_name
- The name of the view to save. The numbers 1-5 are reserved and cannot be used.
- visible
- A flag indicating whether to save the visible entities or not. Valid values are:
- 0 - Save the visible entities and view orientation.
- 1 - Save only the view orientation.
To save a view with the visible entities, with the name "my_view":
*saveviewmask "my_view" 0
# Handle error
