*savefailednodesvectors
Saves the location, magnitude, and direction of the penetrated areas.
*savefailednodesvectors mark reduction scale segment magnitude_mode
HyperMesh Tcl Modify Command
- mark
- The mark of entity to be modified.
- reduction
- The average thickness reduction.
- scale
- The thickness scale factor.
- segment
- The segment orientation option.
- magnitude_mode
- Determines if a magnitude percentage or a uniform size is to be used.
- 1 magnitude percentage
- 0 uniform size
To save the information of the penetration areas:
*createmark groups 1 "E2E"
*savefailednodesvectors 1 0 1 1 0
*createmark() and *templatefileset() are required.
None.
